?? engenius fit AP settings advice needed ??
Solved by Falcon1986,
On 7/18/2023 at 9:48 PM, johnny45 said:iv always done as it seem to defiantly work better with my gear an in my home ,whats the up or down side to doing so
If there's no overlap with any other 5GHz WiFi broadcasts in the neighbourhood, wider channels allow for increased speeds. That's the whole point of moving away from the heavily-congested 2.4GHz. You're only limiting your clients' throughput on a 20MHz width on 5GHz.
Of course, wireless range will fall the wider the channel width, but you can test that out in your home to find the ideal spot.
Please read up more on WiFi-related stuff here.
