Budget (including currency): 500 Euros
Country: Germany
Games, programs or workloads that it will be used for: CSGO AND CS2
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): no
Hello, I want to build my first pc. I made a budget configuration. Would love some feedback what you think about it.
CPU  Ryzen 5 4500 + stock cooler
GPU  Asus Tuf Rx6500Xt
RAM  Vengeance lpx 3200
MAINBOARD  Asus Prime B450m a ii
PSU Evga GQ 600W Gold
SSD Crucial P3 1Tb
CASE Aerocool hive
I can get this brand new for 501,78€. Is it good and how much fps can I get in Cs2? Does anyone know that? Thx
https://linustechtips.com/topic/1519861-first-pc-build/
https://de.pcpartpicker.com/list/znBX9r
3600 + 6800xt + 16gb 3000c16
Might have to settle for abit lower spec irl but if you can verify if the 3600 + cooler and 6800xt deals are legit then go for it
Used part links
3600 + cooler
Rm750x
6800xt
https://linustechtips.com/topic/1519861-first-pc-build/#findComment-16036245
1 hour ago, AdoldonsoXD06 said:
Cs2
600 with all low on a super strong CPU? 2kliksphilip did a video on CS2 vs budget card. Honestly i would go used market for sure.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1519861-first-pc-build/#findComment-16036255
35 minutes ago, AdoldonsoXD06 said:
600
For goodness sake watch the video. Its 600fps according to Philip's testing but in that case the game is very much CPU bounded which means most of the framerates comes by the CPU. In a more GPU sided testing with 1080p on high settings its more like 145-130 fps.
https://linustechtips.com/topic/1519861-first-pc-build/#findComment-16036298
