Thermal paste on cpu question
Solved by Whatisthis,
2 hours ago, Mlady Swagalot said:By ethanol i don't mean using liquer, it's medicinal ethanol.
If it is denatured, do not use it. The additives leave a residue. If it is pure diluted with distilled water (so you can drink it) then it is good to use.
In the US you can’t get non-denatured ethanol readily so we tend to use isopropyl alcohol.
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases6 -
3
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning19
play_circle_filled
Latest From ShortCircuit:
