I would like to replace my Dell E176FP with something a little newer. It's still a really, really, really nice monitor, but I'd like something a little newer for reliability and screen size. My criteria are below. I don't really care about IPS or TN. As long as the panel doesn't suck, I'm happy.
  • At least 22" in size
  • 1080p or 1200p
  • Under $200 USD
  • Matte screen
  • Hopefully still available by Christmas
  • DVI and HDMI. VGA, if possible (otherwise an adapter link will be needed too).
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/151968-help-please/
Is this something you're looking for?
It is nice, but I was thinking something more Dell-ey. If nothing else, that will do fine.
A cheap IPS, or a higher end TN will fit this easily...
Just go check PCpartpicker or something :)
My firewall is being screwey and isn't letting me go there.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/151968-help-please/#findComment-2029446
Acer H236HLbid. I have two in front of me right now, and they're pretty nice.
It's glossy, 1080p, IPS, supports VGA, DVI, HDMI, and is only $150.
Glossy kills it. I'll have to add matte to my list. I know it's nice, but my PC is right by the window, and gloss screens are near impossible to see when it's sunny out.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/151968-help-please/#findComment-2029470
Yes, of course those exist.. So much so, that there are just too damn many to mention.
If you want best picture quality and viewing angles, go for an IPS Panel.
If your sole purpose is gaming and you want fast refresh rates such as 120Hz or 144Hz, go for a TN Panel.
Either way, with your budget of sub-$200 - you'll be able to find some great choices. Such as a budget IPS that looks great, or a mid-high end TN. You could probably even go up to 23"-24" with that budget! Don't worry about one that has a D-SUB (VGA) because for like $5 you could get an adapter for your Dell computer.
Most people of this forum are going to say go with IPS; to which I cannot argue or disagree with.
« Current PC ~ Phantom Beast »
https://linustechtips.com/topic/151968-help-please/#findComment-2029471
not ips at all very very TN
Christian and Proud of it
Please read the CoC        My Build Log
https://linustechtips.com/topic/151968-help-please/#findComment-2029476
Alright, I went to the Deli (Okay, I'll stop now.) and I found this. I'm actually not sure if it has a VGA interface or not, because Newegg doesn't seem to indicate if it does or not, but in PCPartPicker, it says it does have one.
He never said he needed IPS as far as my understanding of the situation goes.
Previously Trogdor8freebird
5800x | Asus x570 Pro Wifi (barely enough for 64GB apparently given it's 2133 and still crashes sometimes) | 64GB DDR4 | 3070 Ti 8GB | Love that whole weeb shit
https://linustechtips.com/topic/151968-help-please/#findComment-2029480
Asus makes affordable 23" IPS panels (under $200)
Got a link? I guess one of those would do fine.
I could care less about IPS/TN guys. All of my monitors are TN, and they're all nice. Hell, my E176FP (the one I want to replace) is TN and it looks pretty great for being 8 years old and TN.
Doesn't seem to load. Nevermind.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/151968-help-please/#findComment-2029486
i have this monitor and i like it a lot or you could get this pretty much the same thing
https://linustechtips.com/topic/151968-help-please/#findComment-2029489
you say that now but once you see a AOC TN panel monitor you will regret buying the monitor(imo)
https://linustechtips.com/topic/151968-help-please/#findComment-2029493
Non-PCPartPicker please (firewall is acting up again).
Mine's pretty nice. Other than the dead pixel right in the middle, I love it.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/151968-help-please/#findComment-2029510
ok  where would you prefer to buy it from
https://linustechtips.com/topic/151968-help-please/#findComment-2029515
Newegg. Maybe Best Buy.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/151968-help-please/#findComment-2029529
what about amazon or microcenter?
https://linustechtips.com/topic/151968-help-please/#findComment-2029552
Amazon sure, Micro Center no. The nearest one is a 3 to 4 hour trip.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/151968-help-please/#findComment-2029564
ok http://www.amazon.com/dp/B00CPZJP7C/?tag=pcpapi-20 or either http://www.amazon.com/dp/B009V8F700/?tag=pcpapi-20
i have the first one and i really like it and it is great in sunlight in my experiences
https://linustechtips.com/topic/151968-help-please/#findComment-2029588
