https://linustechtips.com/topic/1518577-help/#findComment-16027507
On 7/10/2023 at 8:14 PM, TrigrH said:
I did and when i run the set up nothing happens. I then drag it to desktop and then it says  " Does not support this operating system : WNT_10.0P_11_64. Any Idea what to do next?
https://linustechtips.com/topic/1518577-help/#findComment-16027659
Also, I saw a yt video on limiting  Speed And Duplex down to 10 mbps. This did work and my ethernet started working, but like its super super slow -_-. Any idea?
https://linustechtips.com/topic/1518577-help/#findComment-16027660
use this one instead
https://dlcdnets.asus.com/pub/ASUS/mb/04LAN/DRV_LAN_Intel_I225_I226_SZ-TSD_W10_64_V11438_20230322R.zip?model=ROG STRIX B550-F GAMING
https://linustechtips.com/topic/1518577-help/#findComment-16027698
7 hours ago, TrigrH said:
also when i ran the set up it only opened like the black command prompt screen twice for like 1 second each time
https://linustechtips.com/topic/1518577-help/#findComment-16028350
reinstall windows then install that second one
https://linustechtips.com/topic/1518577-help/#findComment-16028747
4 minutes ago, Jaowsa said:
i already did that, switched from windows 10 to 11 nothing
thats the problem
the first link was for 11
the second was for 10
using the wrong driver stuffs everything up.
https://linustechtips.com/topic/1518577-help/#findComment-16028769
On 7/11/2023 at 5:38 PM, Whatisthis said:
let’s start from the very beginning.
How old is the computer?
What are your full system specs?
What drivers have you installed?
Have you update the bios to the latest?
What OS are you running now?
My new Pc Is fairly new, i fully built it yesterday.
 3070 TI
4X8 3600
1 TB NVME SAMSUNG 970
Ryzen 7  5800x
850 Corsair PSU.
I tried installing the ones from the Asus website, they dont even run. I tried straight from intel, nothing.
Bios has been updated.
I tried windows 10, plugged in my ethernet, nothing. Tried the same drivers I mentioned above^
I am currently using windows 11.
https://linustechtips.com/topic/1518577-help/#findComment-16029152
by any chance do you think this could be an ethernet cable problem? Its Cat  5e and it works on my old pc its not super old.
https://linustechtips.com/topic/1518577-help/#findComment-16029159
It doesn’t sound like a cable issue, but networking can be weird. If you have another cable test it out.
If the drivers are up to date for the chipset and the lan controller and it refuses to work with two different cables, you probably have a mamlfunctioning chip on the motherboard.
https://linustechtips.com/topic/1518577-help/#findComment-16029161
well Ive seen many reddit and pc website posts about them having this same issue. My main problem is the hassle I'm gonna go through to do an RMA. I'm going to check if I have any other cables.
https://linustechtips.com/topic/1518577-help/#findComment-16029178
On 7/11/2023 at 5:57 PM, Whatisthis said:
See above, I edited.
I'm not sure if I mentioned this already, but when i first plugged in my ethernet cable, it didnt work. When I changed the speed and duplex down to 10 MBPS FULL Duplex, my ethernet worked, but it is very slow. Do you still think its because of the motherboard?
https://linustechtips.com/topic/1518577-help/#findComment-16029179
Test a second cable. Like I said, networking can be very finicky. It could be the chip on the board, it could be the cable.
https://linustechtips.com/topic/1518577-help/#findComment-16029193
