best low tdp gpu ?
1 hour ago, CasoF13 said:well i currently am building a media / starbound local server and to cut cost i thought going with a celeron would be best (lga1200) but someone from the ltt forum here recommends at least a i3. ok good but used i3 lga1200 cost used as much as some i5 Only IF they have a igpu. i3 without the igpu are dirty really dirty cheap used so my question is are there ANY dGpus that are so low in tdp that they would be a viable alternative for a non f igpu cpu ? performance ist not important as long as its at least as strong as a igpu. tdp and ultra cheap price is king for this project. any recommends ?
The RX550. I had one as an emergency GPU for (low settings 720p) gaming while my more powerful card were under repair. In my case, it consumes like 35-40W tops. And since you're running a Starbound server, the RX550's performance should be enough.
Otherwise there's also the NVIDIA equivalent, the GT1030.
