Suggestions for $2400 usd build
This is very similar to a build I'm doing right now for my wife. There are other options for the cooler though.
https://pcpartpicker.com/product/fxJgXL/vetroo-v360-52-cfm-liquid-cpu-cooler-vt-aio-v360-wt
The pink flow is harder to find here in the states, and is what we went with. We ordered it from Aliexpress. It's on Newegg for a bit more than Aliexpress though.
https://www.newegg.com/p/1YF-00B0-00UT2
Another note is that the Lian Li isn't going to come with fans. If we ignore that for a minute, you can get a 7900 xtx and a power supply with white cables into a $2400 budget.
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor ($439.00 @ B&H)
CPU Cooler: Vetroo V360 52 CFM Liquid CPU Cooler ($109.99 @ Amazon)
Motherboard: Gigabyte B650 AERO G ATX AM5 Motherboard ($239.99 @ Amazon)
Memory: Corsair Vengeance RGB 32 GB (2 x 16 GB) DDR5-6400 CL36 Memory ($122.69 @ Amazon)
Storage: Samsung 980 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($99.99 @ Adorama)
Video Card: PowerColor Hellhound Spectral Radeon RX 7900 XTX 24 GB Video Card ($1069.99 @ Amazon)
Case: Lian Li O11 Dynamic EVO ATX Mid Tower Case ($154.90 @ Amazon)
Power Supply: Thermaltake Toughpower GF1 Snow - TT Premium 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($139.99 @ Amazon)
Total: $2376.54
Generated by PCPartPicker 2023-07-06 14:45 EDT-0400
Fans to match the AIO are $33 for a 3 pack and controller, but they can also hook up to your motherboard directly and don't need the controller.
https://www.amazon.com/Vetroo-Controller-Addressable-Motherboard-Computer/dp/B08K74TX3P?th=1
I know the struggle of wanting the Gigabyte Aero. If you go with it, make sure you use a support bracket for it.
