Need Help Formatting a Drive
Solved by johnno23,
if your new drive is registered as your C drive and seen as the C drive under This PC within windows then you should be able to just format the old drive.
14 minutes ago, HeliturtleOP said:the old one was pinned at 100%usage for a while inexplicably
Might have been indexing ? after all your C drive was changed and the older drive was seen as an extra drive and the system makes an index of what is stored on it.
