Strange. I never had this issue  :huh: I'll look into it
https://linustechtips.com/topic/151664-help-fraps-audacity/#findComment-2025429
Sometimes this has to do with recording with a variable framerate, then when you put it on a 30fps timeline the video gets stretched and squashed a tiny bit resulting in the video being made slightly longer or shorter in certain areas
Perhaps try and re-encode or convert the video?
I am really not sure how to fix it though
https://linustechtips.com/topic/151664-help-fraps-audacity/#findComment-2025436
Is audacity needed? I thought the built in sound recorder in FRAPS is just fine especially with a quality mic.
CPU: i7 2600 @ 4.2GHz  COOLING: NZXT Kraken X31 RAM: 4x2GB Corsair XMS3 @ 1600MHz MOBO: Gigabyte Z68-UD3-XP GPU: XFX R9 280X Double Dissipation SSD #1: 120GB OCZ Vertex 2  SSD #2: 240GB Corsair Force 3 HDD #1: 1TB Seagate Barracuda 7200RPM PSU: Silverstone Strider Plus 600W CASE: NZXT H230
CPU: Intel Core 2 Quad Q9550 @ 2.83GHz COOLING: Cooler Master Eclipse RAM: 4x1GB Corsair XMS2 @ 800MHz MOBO: XFX nForce 780i 3-Way SLi GPU: 2x ASUS GTX 560 DirectCU in SLi HDD #1: 1TB Seagate Barracuda 7200RPM PSU: TBA CASE: Antec 300
https://linustechtips.com/topic/151664-help-fraps-audacity/#findComment-2025451
Most likely fraps problem, make sure there is no lag and also your write drive can write at atleast 120mb/s
Beneath this mask there is more than flesh. Beneath this mask there is an idea, Mr. Creedy, and ideas are bulletproof.
As I get older I get angrier more cynical, meaner. I feel some warning posts coming. I feel a ban coming. I was warned.
CPU-i5 2400 GPU-Sapphire Radeon HD 7970 OC Mobo-H67MA-D2H-B3 Ram-G.Skill Ripjaws 8gb 1333mhz Case-Fractal Define R4 PSU-Corsair CX750 Storage-Samsung EVO 250gb, 1tb WD Black,Hitachi 1tb Other stuff-Corsair K90, M90 Cooling-3x 140mm Fractal fans Sound-Sennheiser HD438 headphones
https://linustechtips.com/topic/151664-help-fraps-audacity/#findComment-2025492
yup no lagg and a write speed of 154mb/s
MMM...how much out of sync. Try record with default then with Audacity and see if theres still lag. Reason I think it's fraps is I have used it to sync up music and vid before and it works.  Maybe it cuts the audio by a second somewhere. See if you can pinpoint where it goes out. It seems weird.
https://linustechtips.com/topic/151664-help-fraps-audacity/#findComment-2025525
