APU not recognizing second monitor
Solved by Agall,
6 minutes ago, kjgruber said:I sold my GPU the past week, with intentions of only running an APU but it is only recognizing one display. It is only recognizing whichever display i connect with display port. The HDMI port on the Mobo does not work. Is there something I need to enable in the bios. I know for a system running an GPU and APU, there often is but I can not find any settings for just an APU
System:
AMD Ryzen 5 5600g
MSI b550 gaming plus
Asus ROG Swift PG259QN
No caveats for both display outputs working simultaneously on something like a 5600g. I'd look at reinstalling the driver, otherwise you might have a physical issue with the HDMI port.
