Ryzen 7 3700x High Temps with Arctic Liquid Freezer II 240
Solved by WereCat,
5 minutes ago, Sinistra09 said:I ran Cinebench and the CPU peaked at around 81.5C. I also used the standard Ryzen mounting but I don't imagine that the offset would make that much of a difference to where my idle temps are almost always above 50c.
81.5 C is perfectly fine. Seems like just high idle voltage is causing higher idle temps which is not really an issue either.
Featured Topics
RanchTheHay005 ·
1
2
alexfic ·
Posted in New Builds and Planning3 -
Pirateben ·
Posted in General Discussion1 -
frozensun ·
Posted in Storage Devices1 -
3
ammar666 ·
Posted in Troubleshooting4
