Hello all!
So I'm upgrading my computer, and had some questions.
I'm adding a second GPU, and changing my CPU, and adding Water Cooling.
So curious as to my power needs, I pulled up a PSU calculator, and it told me I needed 970w for my rig...
The settings I chose in it are:
        1 Physical CPU, High End Desktop, 4670k, Overclocked to 4500 with 1.35V (guestimation), 2 sticks DDR3, 2 GTX 780's, 2 HDDs 7200rpm, 1 DVD-RW/DVD+RW Drive, 1 Flash SSD Drive, 4 USB Devices, Fan Controller, 8 120mm Reg Fans, 6 High Performance fans, Swiftech MCP 655 Pump, 90% load, 25% Capacitor Aging.
Do I need a 1000w PSU? Or would the 750w I own be enough? (I have a 1200 in the mail, but it's won't be here when the rest shows)
Case: Lian Li PC011-D - CPU: 3900x - GPU: 2080ti Reference - Mobo: Gigabyte - Ram: Corsair 4x16gb 3200MHz - SSD: 2TB Samsung Evo NVME
https://linustechtips.com/topic/151557-enough-power/
Honestly I would get the 1000w. 750w would probably do fine for non oced cpu and sli gpus, but when you add in a ton of fans, a pump, overclocks, ect, it adds up.
I am running a 4670k and 770 off 450w, and I can't oc because my psu isnt enough, so take my words of advice :P
https://linustechtips.com/topic/151557-enough-power/#findComment-2023913
You can OC for sure, just don't use a ton of voltage.
https://linustechtips.com/topic/151557-enough-power/#findComment-2023925
My plan until I can get the 1200w here, Is to chill at stock temps.
https://linustechtips.com/topic/151557-enough-power/#findComment-2023932
Oh lol. You sure it was not enough power not just an unstable OC.
1.25v 4.4ghz cpu
1.5v 1333 ram
1.9v on that thing that I cant remember what its called
pretty sure I deed it right, and I'm using an nt06-pro with an nff12, so temps weren't the problem.
https://linustechtips.com/topic/151557-enough-power/#findComment-2023953
1.25v 4.4ghz cpu
1.5v 1333 ram
Try like 1.28 or something. I only use 410w under 100% load so you're fine.
https://linustechtips.com/topic/151557-enough-power/#findComment-2023967
