Hey guys,
I just measured the amount of power, that my pc draws from the wall while sitting at idle at the desktop. Its about 110W. My CPU is a 5900x and my GPU a gtx 1070. I run a custom water cooling loop. Is there a way to reduce the idle power consumption?
I am running the windows balanced power setting for ryzen, which came with the chipset driver.
Thanks for your help
https://linustechtips.com/topic/1515447-reducing-desktop-power-consumption/
17 minutes ago, Devryd said:
Hey guys,
Only thing I can suggest is looking into undervolting your CPU in the bios. Generally CPUs draw more voltage than they actually need, with it being possible to lower that to some degree without affect performance.
Also as far as power profile goes, if you're going to be doing any gaming or productive tasks, it's strongly recommended to use high power profiles for that.
Your loop is whats consuming power as a pump is quite a bit of wattage
A 1070 is not the most efficient card
5900x can go in eco mode.
But basically a typical custom loop pump goes between 14-25w.
Then if you have lots of fans that some wattage each
rgb isnt little either
And then the components that make the pc work.
Have you tried enabling ECO mode for your cpu in your bios? I'm not sure if that helps while idling though (might only reduce power draw under load) but it's worth a shot. It's really easy to do as well. It's a setting somewhere around the overclocking options.
