There is a 32in, 240hz, 4k monitor due out soon. I was planning on getting two of them for uniformity, but the secondary one is strictly for reading; Discord, Steam, webpages, etc. Absolutely no gaming will be performed on it. However watching the following video, letter quality is much better on the current monitors. With that, I don't see a reason to wait in getting a side panel now if it exist.
I am looking for a side panel that will be rotated 90 degrees with the following specs:
  • 4k,5k or 6k (without a webcam attached)
  • 32 or 34 in
  • 120hz
  • 10bit color
Can I get some recommendations please?
Edit: Or do you think because the screen will be larger than what is tested, it won't be an issue on the future 32in OLED monitors?
https://linustechtips.com/topic/1514905-side-panel-recommendations/
One monitor I could think of is Gigabyte AORUS FI32U that supports 90 degrees rotation, or you can grab any cheaper monitor and a monitor arm.
PC spec: CPU: RYZEN 9 9950X3D | GPU: SAPPHIRE NITRO+ 7900XTX | MB: MSI MAG TOMAHAWK x870 RAM: G.SKILL TRIDENT Z NEO 64GB (2x32GB) DDR5-6000 30-40-40-96 COOLING: ARCTIC LIQUID FREEZER III 360, BE QUIET! SILENT WINGS 120 & 140mm| CASE: ANTEC C8 | UPS: POWERSHIELD COMMANDER TOWER 1100VA
PERIPHERALS: KEYBOARD: CORSAIR K95 PLATINUM XT BROWN SWITCH | MOUSE: LOGITECH G502X PLUS WIRELESS | CONTROLLER: PDP AFTERGLOW WIRED CONTROLLER, DUALSENSE
DISPLAYS: GIGABYTE MO34WQC2 2x DELL S2721DGF | LG C1 48"
HT & audio stuff:  AVR: MARANTZ SR7013 | STEREO AMPLIFIER: YAMAHA AS-501 | SPEAKERS: DALI OBERON 7 & DALI ZENSOR 1 & 2x SVS-SB2000 | HEADPHONE DAC+AMP: TOPPING L30+E30 | HEADPHONE: SENNHEISER HD6XX, BOSE QUIETCOMFORT 35 II | MICROPHONE: AUDIO-TECHNICA AT9934USB | BLU-RAY PLAYER: PANASONIC UB820
