Upgrade from gtx 970 and maybe more?
Solved by filpo,
On 6/21/2023 at 9:11 AM, qnz said:hello guys, im back sorry.
with a 250/300€ budget what would you guys recomend me? anything should be better that that old gtx 970 right? dont want to overspend on a gpu right now.
ASUS Dual GeForce RTX 3060 OC Edition 8GB GDDR6
299.90€
is this decent?
Don't get a 3060 8 Gig. Its essentially an overclocked 3050 with some more cores
The 6650 xt might just scrape in your budget it will perform much better Asus DUAL Radeon RX 6650 XT 8 GB Video Card (DUAL-RX6650XT-O8G) - PCPartPicker
But you could go used for a 3070 and it would be better than the 6700 xt ZOTAC GeForce RTX 3070 Twin Edge OC, Grafikkarte | eBay
