How do I convert WIFI to ethernet?
Pahbi
I have a few devices that are ethernet only that I want to connect to internet via WIFI, a device with 4 ports would be perfect.  Oh, and the cheaper the better, these devices don't need much speed.
Any thoughts on this?
I have a feeling its something simple and easy that I'm overlooking, but I'd appreciate any help.
Thanks
What kind of devices?
A converter (if they exist) would require drivers, which may or may be difficult for your device to use.
Alternately, USB wifi...
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
Some access points can be put into client mode, i.e. an AP in reverse, connects to an existing WiFi network and provides Ethernet ports. That's the keyword you're after.
F@H
Desktop: i9-13900K, Noctua NH-D14, ASUS Z790-E, 64GB DDR5-6000 CL36, RTX3080, 2TB MP600 Pro XT, 2TB SX8200Pro, 2x16TB Ironwolf RAID0, Corsair HX1200, Thermaltake Versa H25 TG, Samsung 4K curved 49" TV, 23" secondary, Mountain Everest Max
GPD Win 2
