PC Build Plan Review for Friend (New Streamer)
15 hours ago, SorryClaire said:Sadly yeah. AMD VCN is only good with the AV1 support that RX 7000 series shows and that's really more credit to AV1 being an insanely efficient video encoding protocol than AMD video encoder design. On H.264 which Twitch uses right now, they easily got their ass handed in quality. Although Intel Quick Sync Video in the integrated graphics of Intel CPU is a bit cheaper and the quality is indeed better than AMD's. But that means you have to use OBS for the most part because Intel doesn't have a built in screen recording software. If they're into Nvidia software suite its going to be a hard negotiation to clear.
Since that's the case, I guess we'll go for the 4070 for the $100 more.
15 hours ago, SorryClaire said:10% higher on productivity and 5% higher in 1080p gaming where CPU actually matters. Its not bad of an upgrade really.
Since it's not a significant difference, and with the build I have currently selected being at $2000 exact, I think I'll stick with the 12700KF. I can't see 5% being worth the extra $100 dollars.
Here is the final parts list I have compiled thanks to everyone's suggestions. I will probably order everything today since several sales for the parts end in about 14hr.
CPU: Intel Core i7-12700KF 3.6 GHz 12-Core Processor ($239.99 @ Newegg)
CPU Cooler: *Deepcool AG620 67.88 CFM CPU Cooler ($48.98 @ Newegg)
Motherboard: *MSI B760 GAMING PLUS WIFI ATX LGA1700 Motherboard ($164.99 @ Amazon)
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($105.99 @ Amazon)
Storage: *Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($99.00 @ Newegg)
Storage: *Seagate Barracuda Compute 2 TB 3.5" 7200 RPM Internal Hard Drive ($49.99 @ Amazon)
Video Card: Gigabyte WINDFORCE OC GeForce RTX 4070 12 GB Video Card ($599.99 @ Newegg)
Case: *Fractal Design Focus 2 ATX Mid Tower Case ($60.98 @ Newegg)
Power Supply: FSP Group Hydro G Pro 750 W 80+ Gold Certified Fully Modular ATX Power Supply ($85.99 @ Newegg Sellers)
Operating System: *Microsoft Windows 11 Home OEM - DVD 64-bit ($99.99 @ Newegg)
Case Fan: ARCTIC P12 56.3 CFM 120 mm Fan ($9.99 @ Amazon)
Monitor: Acer Nitro QG241Y Pbmiipx 23.8" 1920 x 1080 165 Hz Monitor ($119.99 @ Amazon)
Keyboard: *Logitech G610 Wired Gaming Keyboard ($60.99 @ Amazon)
Mouse: *Razer DeathAdder V3 Optical Mouse ($69.98 @ Amazon)
Headphones: *SteelSeries Arctis Prime Headset ($49.99 @ Amazon)
Total: $1986.82
Generated by PCPartPicker 2023-06-10 13:10 EDT-0400
UPDATE: Ordered everything, total after tax/shipping was $2,149.49 USD.
