Pwm splitter cable
By
RandomNeedsHelp
in Cooling
in Cooling
Solved by IkeaGnome,
That missing pin is the pin that sends a tachometer signal to the motherboard. If you had 2 fans reporting speeds to the same header, the header gets confused. This is normal and the fan that will have speed read is the one with the 4 pin.
l3eyond ·
1
Serendipity1344 ·
Posted in Graphics Cards4 -
1
1
5
1
toxic_worper ·
18
