right cablemod sett
Go to solution Solved by gen_angry,
The only thing that matters for cablemods is that you get the right type of cables for the power supply that you have (so in your case, Corsair RM850e -> C-Series Type 4 according to this list). None of the other specs really matter as it's all standardized.
So any of these should work (or custom if you're looking to go that route).
Main: 5900X | RTX 3070 | Gigabyte x570 Aorus Elite | 32GB DDR4-3600 | 1TB SN750 + 2TB WD SATA SSD
WinXP: Ph2 945 | GTX 750 Ti | Asus M4A79XTD-EVO | 8GB DDR3-1600 | 320GB WD HDD
DOS/Win95: 200MMX | S3 Trio64v2/DX + Diamond Monster 3D | Asus P5-99VM | 64MB PC100 | 80GB IDE HDD
Apple IIe Enh.: 65C02 | 64K RAM | 2xDisk II | SSC - Post
https://linustechtips.com/topic/1511640-right-cablemod-sett/#findComment-15975313
What you mean set? You go to cablemod's site and chose which cables you want. Usually these are 24pin, 8pin (or 2x4) EPS and 3x PCIe 6+2pin.
But €2500 for a 4070 build is just a f**king crime.
Also, as someone who has the exact same Asus monitor you posted there, if you haven't bought the system yet, change the monitor to LG 27GP850-B
| Ryzen 7 5800X3D | Arctic Liquid Freezer II 360 Rev 7| AsRock X570 Steel Legend |
| 4x16GB G.Skill Trident Z Neo 4000MHz CL16 | Sapphire Nitro+ RX 6900 XT | Seasonic Focus GX-1000|
| 512GB A-Data XPG Spectrix S40G RGB | 2TB A-Data SX8200 Pro| Phanteks Eclipse G500A |
https://linustechtips.com/topic/1511640-right-cablemod-sett/#findComment-15975318
Yes I know
5 minutes ago, QuantumSingularity said:
Also as some who has the exact same Asus monitor you posted there, if you haven't bought the system yet, change the monitor to LG 27GP850-B
I need a 100x100 mount so thats not really an option why not the Asus
OK I will try
https://linustechtips.com/topic/1511640-right-cablemod-sett/#findComment-15975333
The Asus is worse in every single possible metric, including build quality. But i understand about the VESA mount. If you are not constricted by space then, get the Dell G3223D. Not DGF, just D. It's basically the same monitor, but it's "32 inches instead of "27, has better brightness, FreeSync Premium Pro in addition to G-sync, USB-C and it's 2 years newer. I really wish i knew this when i was buying the Asus half a year ago.
https://linustechtips.com/topic/1511640-right-cablemod-sett/#findComment-15975621
What if it has a Vesa mount?
https://www.lg.com/us/monitors/lg-27gp850-b-gaming-monitor#
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1511640-right-cablemod-sett/#findComment-15975631
  Reveal hidden contents
Oh f**k... i went with PcPartPicker desribtion and didn't even check in google. It DOES have VESA 100x100. It's the clear choice then. It's truly so much better. Supports 10-bit color over DP up to 180Hz where the Asus tops out at 120Hz.
https://linustechtips.com/topic/1511640-right-cablemod-sett/#findComment-15975649
I only looked because it seemed odd for it to not have one when even the G9 has 100x100. Not sure I'd trust a 100x100 mount with my monitor though when it gets to be that heavy.
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1511640-right-cablemod-sett/#findComment-15975653
55 minutes ago, Apfelholz said:
better 😉
I still have my own opinion against the 4070Ti , ESPECIALLY at €1000 price tag, but it is what it is. Personally for that price i'd go 7900XTX, but then i'd mainly use it for gaming so...
https://linustechtips.com/topic/1511640-right-cablemod-sett/#findComment-15975745
12 hours ago, QuantumSingularity said:
better 😉
Yes then that would be a better choice I also have some other things to do and so I really benefit from nvidia
https://linustechtips.com/topic/1511640-right-cablemod-sett/#findComment-15976427
