Are Ryzen 7 5800x3D's normaly very hot?
Go to solution Solved by Shimejii,
6 minutes ago, Drakonins said:
Hmm ok, thanks I'll try to repaste refit cooler I hope It will work, maybe too much paste was added.
I had problems with ram so i had to refit CPU cooler multiple times to access ram.
are you using PBO2 Tuner? NH-D15 Without it yeah its gonna get quite toasty. I suggest getting PB02 Tuner, doing -25 all cores, 120W PPT, 80A TDC, 110 EDC on page 2.
What fan speed are you running the fans at?
So I have Ryzen 7 5800x3D with Noctua NH-D15 on B550 Tomahawk motherboard and it runs in games under 80°c, even 90°c+ at 100% usage in Need For Speed Heat (no wonder why it's called NFS Heat lol).
Should I let It sit around those temps or should I upgrade to High-End water cooling, If so any ideas what should look for?
Idle temps are around 35-45°c
Paste on CPU is enough and I have tried to reseat cooler multiple times.
On i7 8700k at 5GHz It was cooling just fine (in games, not benchmarks).
Repaste?
CPU-AMD Ryzen 7 7800X3D GPU-ASUS TUF RTX 4070Ti MOBO-ASUS ROG Strix B650E-E Gaming Wifi RAM-32gb G.Skill Trident Z5 Neo DDR5 6000cl30 STORAGE-2x1TB Seagate Firecuda 530 PCIE4 NVME PSU-Corsair RM1000x Shift COOLING-EK-AIO 360mm+7x Phanteks T30s CASE-Phanteks G500a MONITORS-ASUS ROG Strix XG27AQ 1440p 170hz+Gigabyte G24F 1080p 180hz PERIPHERALS-Lamzu Atlantis+LGG Saturn Pro Mousepad+Nk65 Watermelon (Tangerine Switches)+Autonomous ErgoChair+ AUDIO-RODE NTH-100+Schiit Magni Heresy+Motu M2 Interface
Repaste and refit cooler, double check fan speeds. That said, the 5800X3D is supposed to run a bit hotter than the 5800X despite drawing less power due to the 3D cache design. For both CPUs, AMD said they are safe up to 90C. These CPUs are smart, if you hit 90C they will try their absolute best to still maintain their turbo speed without activating the throttle button.
Those temps are generally observed under benchmarking though, NFS Heat is not a CPU-intensive game generally but who knows...
7800x3d - RTX 4090 FE - 64GB-6000C30 - 2x2TB 990 Pro
PCPP: https://uk.pcpartpicker.com/list/jGyqsh
umm I'm only using curve of speed in BIOS 80°c at max speed, I'll look up PBO2 Tuner.
And I think I fixed my problem atleast for now, I opened window and temp droped from 91°c to 80°c x)
Was it a repaste that fixed it?
nop I opened window and in 20~min it droped like 8-10 degres, tho It won't work in hot days, now It's pretty chilly outside, 80°c now.
I don't have paste at the moment to repaste but in a week I will try It!
Got from 85°c 130W to 73°c - 75°c 120W under benchmark load so for gaming It will be even more better.
Thanks, I will leave your comment as answer but later this week I will try repaste as well!
Dont need to repaste, those are pretty much my thermals as well. Those are the to be expected gains! 10-12C a nice gain 🙂
