Endorfy Supremo FM5 Gold 850W not turning on, makes weird click noise
Solved by Whatisthis,
The click in a psu sometimes means there is a protection circuit that is getting tripped. Since it’s not working, I assume that is what’s happening.
Unplug all the cables from the unit except the atx connector. Short pins 4 and 5 with a paper clip. This will turn the unit on. If it clicks and you don’t get any signs of life, it’s bad.
here is some pics of the process: https://www.silverstonetek.com/upload/downloads/QA/PSU/PSU-Paper Clip-EN.pdf
sometimes the cables are bad and cause the issue, so plug in all the cables you will use into the psu (not into components) and try the paper clip again if it started with just the atx connected.
