Budget (including currency):  800 CAD
Country: Canada
Games, programs or workloads that it will be used for: Modern Warfare 2, and other FPS shooters
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): 1080p 120Fps possibly streaming once I’ve upgraded further.
https://pcpartpicker.com/list/dgm6Tn
Just making sure I’m spending my money right, and planning for a future. Need some opinion on the longevity with this build, and parts to splurge on to not have to upgrade sooner rather then later. Thanks for your help ahead of time!
https://linustechtips.com/topic/1510967-first-pc-build/
PCPartPicker Part List
CPU: *Intel Core i3-12100F 3.3 GHz Quad-Core Processor  ($124.50 @ Vuugo)
CPU Cooler: *Deepcool AG400 75.89 CFM CPU Cooler  ($31.48 @ Vuugo)
Motherboard: *MSI PRO B660M-A DDR4 Micro ATX LGA1700 Motherboard  ($149.99 @ Newegg Canada)
Memory: *TEAMGROUP T-Force Vulcan Z 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($39.97 @ Newegg Canada)
Storage: *TEAMGROUP AX2 1 TB 2.5" Solid State Drive  ($59.99 @ Amazon Canada)
Video Card: *Gigabyte EAGLE Radeon RX 6600 8 GB Video Card  ($249.99 @ Canada Computers)
Case: Deepcool MATREXX 40 MicroATX Mini Tower Case  ($89.98 @ Newegg Canada)
Power Supply: Corsair CX650M (2021) 650 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($104.50 @ Vuugo)
Total: $850.40
Generated by PCPartPicker 2023-06-03 18:54 EDT-0400
https://linustechtips.com/topic/1510967-first-pc-build/#findComment-15970094
Country: Canada
Wait... 800 CAD? You know this list is in USD right? o_O
I got it closer to 800 CAD, although I think the motherboard is a little overpriced. (Definitely don't go with those cheap ASRock motherboards though, as you may as well buy a cheap prebuilt)
https://ca.pcpartpicker.com/list/qnVJjZ
CPU: AMD Ryzen 5 5500 3.6 GHz 6-Core Processor  ($129.00 @ Newegg Canada)
CPU Cooler: Deepcool AG400 BK ARGB 75.89 CFM CPU Cooler  ($39.99 @ Amazon Canada)
Motherboard: Gigabyte B550M DS3H AC Micro ATX AM4 Motherboard  ($134.99 @ Amazon Canada)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($49.99 @ Canada Computers)
Storage: Western Digital Black SN770 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($74.97 @ Amazon Canada)
Video Card: Gigabyte EAGLE Radeon RX 6600 8 GB Video Card  ($249.99 @ Canada Computers)
$873.41
Am I still to create the perfect system?! ~ Clu
Keep your expectations low, boy, and you will never be disappointed. ~ Kratos
https://linustechtips.com/topic/1510967-first-pc-build/#findComment-15970100
