I got a 3070 about 6 months ago and just the past day its been giving me some issues that im worried about, its caused stuff like Google to stop working periodically, I've seen a few artifacts on my screen twice but wasnt able to get images, it wasn't like a ton of them it was just some placed throughout the monitor, while my gpu was under no load, and at only 46 celsius, its turned both of my monitors of and on several times, a few times it has randomly spiked to 100% use for a split second and it just instantly crashes discord and also has made like only specific parts of it kinda bleed down? idk. I've changed nothing about it ever, except for just allowing it to use its fans a little bit more because the noise isnt a problem for me. is my card dying?
https://linustechtips.com/topic/1510813-issues-with-3070-fe/
Was this thing used or new?  How hot does it get under load?
https://linustechtips.com/topic/1510813-issues-with-3070-fe/#findComment-15969312
27 minutes ago, MoonMan. said:
i got it lightly used off of ebay, and it gets around 90 under load
90 may be bingo for that card.  I don’t know.
https://linustechtips.com/topic/1510813-issues-with-3070-fe/#findComment-15969335
which model of 3070 specifically here? Also what case?
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1510813-issues-with-3070-fe/#findComment-15969351
Latest driver and also a firmware update might fix it. I had to flash mine when I got it second hand 7 months ago.
Intel Core i7-14700F | ASUS Z690M PLUS D4 | 2x16GB DDR4 @ 3600MHz CL16 | Zotac RTX 4070 SUPER 12GB | WD SN770 2TB SSD | Fractal ION+ 860W Platinum | Fractal Focus G Mini Case | Alienware 27" 1440p 240Hz G-SYNC Ultimate | Logitech THX 2.1 Speakers | Windows 11 Pro
https://linustechtips.com/topic/1510813-issues-with-3070-fe/#findComment-15969916
It literally says fe in the title...
you could try new drivers if available or run DDU and reinstall drivers. You can also try changing to another 16x slot.
https://linustechtips.com/topic/1510813-issues-with-3070-fe/#findComment-15971255
Yeah but who made it one could eventually figure it out with reverse lookup but the actual manufacturer (asus, power color, evga (just joking) etc.. is handy to have.
https://linustechtips.com/topic/1510813-issues-with-3070-fe/#findComment-15971511
