Phantom power mic
Solved by Hans Christian | Teri,
Only one suggestion peeps?!
I'm thinking this instead LInk @Hans Christian | Teri As the reviews for the one you suggested seemed to say that Phantom power mics don't work very well with it.... What do you think? Also I think I would only need something like this to connect it to my computer Link Correct?!
Or This Link... Not sure
I own and use the Xenyx 802 myself. Great bang for your buck, you just need (as you point out yourself) an RCA to stereo mini jack cable to plug it into your computer. Works great. ![]()
