Hello there,
I already have two very similar Builds. Most tell me to go with AMD, I'd too. Problem is ,that I want to Stream. I thought that I could use my capture card and stream from my old pc. There are two things now, can I duplicate the screen that I am gaming on so that I see my Main gaming on the good monitor and the same is captured on the old pc. My goal is to use as much of the pcs power as I can. Does it make sense what I'm thinking? Second is, if the first doesn't work, my mobo on the AMD build doesn't have PCIex1 slots, can't the capture card still go in? And are there extensions for PCIex1, otherwise my old pc can't fit them in. If you can make any changes that are profitable, pls tell me!
Thanks!
AMD:
PCPartPicker Part List: https://de.pcpartpicker.com/list/hYMQpH
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  (€473.99 @ Mindfactory)
CPU Cooler: Deepcool LT520 85.85 CFM Liquid CPU Cooler  (€120.79 @ Galaxus)
Motherboard: Gigabyte B650 GAMING X AX ATX AM5 Motherboard  (€204.90 @ Alza)
Memory: Corsair Vengeance RGB 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory  (€119.99 @ Amazon Deutschland)
Storage: Samsung 970 Evo Plus 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (€104.26 @ Galaxus)
Video Card: Gigabyte AORUS MASTER GeForce RTX 4070 Ti 12 GB Video Card  (Purchased For €0.00)
Case: Deepcool CK560 ATX Mid Tower Case  (€99.90 @ Alza)
Power Supply: SeaSonic FOCUS GX 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For €0.00)
Custom: Lian Li Strimer Plus V2 24-Pin RGB Mainboardkabel  (€68.00 @ Amazon Deutschland)
Custom: Lian-Li Strimer Plus V2 12VHPWR 3X 8- zu 16-Pin Verlängerung - 335mm, 8 LED-Bahnen  (€64.95 @ Amazon Deutschland)
Total: €1256.78
Generated by PCPartPicker 2023-05-30 09:45 CEST+0200
Intel:
PCPartPicker Part List: https://de.pcpartpicker.com/list/P3RnZw
CPU: Intel Core i7-13700F 2.1 GHz 16-Core Processor  (€394.97 @ Amazon Deutschland)
Motherboard: Gigabyte Z790 UD AX ATX LGA1700 Motherboard  (€229.90 @ Alza)
Total: €1202.76
Generated by PCPartPicker 2023-05-30 09:46 CEST+0200
I hope I could help! Please @Cazmoriorso that I can reply quicker!
Note:
Not everything I write must be right! I mostly only use what I already know and things I have heard. My main information source is LinusTechTipps. You can check out my other profiles:
Twitch: https://m.twitch.tv/cazmorior/home
Insta: https://instagram.com/mat_lutz?igshid=YmMyMTA2M2Y=
Thanks for visiting! Have a great day!
https://linustechtips.com/topic/1510046-some-problems-and-general-questions/
I wish I could help with the capture card but I've never used one myself.
https://geizhals.de/   <--- check this site for better prices on PC components.
Case with 2x140mm front intake + 1x120mm exhaust, fast low latency RAM and it's low profile so that it doesn't impede that dual tower cpu cooler.
CPU: *Intel Core i7-13700F 2.1 GHz 16-Core Processor  (€394.97 @ Amazon Deutschland)
CPU Cooler: *Deepcool AG620 BK ARGB 67.88 CFM CPU Cooler  (€64.98 @ Amazon Deutschland)
Motherboard: *MSI B760 GAMING PLUS WIFI ATX LGA1700 Motherboard  (€185.69 @ Amazon Deutschland)
Memory: *G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (€130.88 @ Amazon Deutschland)
Storage: *Samsung 970 Evo Plus 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (€104.26 @ Galaxus)
Case: *Fractal Design Focus 2 RGB ATX Mid Tower Case  (€82.90 @ Amazon Deutschland)
Case Fan: *ARCTIC P12 56.3 CFM 120 mm Fan  (€5.37 @ Aquatuning)
Total: €969.05
Generated by PCPartPicker 2023-05-30 10:30 CEST+0200
A better look at those components.
https://www.fractal-design.com/products/cases/focus/focus-2/rgb-black-tg-clear-tint/
https://www.msi.com/Motherboard/B760-GAMING-PLUS-WIFI
https://www.deepcool.com/products/Cooling/cpuaircoolers/AG620-BK-ARGB-Dual-Tower-CPU-Cooler-1700-AM5/2022/16082.shtml
That is the main MO of a capture card. EposVox made a really old video on the basics of it but i dont know if he has updated it since his dissolution with capture card market.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
