4000D Airflow vs H5 Flow: Which Case?
Rob_dog
So I have stumbled upon 2 cases: the Corsair 4000D Airflow and the H5 Flow. They are both excellent, but which one should I get? I can't decide. Which is better?
Specs:
RTX 4080
5800X
280mm radiator (top mounted for 4000D, front mounted on H5)
43 minutes ago, Rob_dog said:
RTX 4080
Which 4080 specifically?
5800X
I would get the cc560 as it has a top 280 rad mount and 4 included fans
Mark the solution as solution
Take my advice with a grain of salt.
As a great AI once said (fictional): '"Whenever your futurists envision the advent of artificial intelligence, their predictions invariably end with humanity attempting to destroy its unholy AI creation before it can destroy them. Why do you think that is?"'
And a distrusting human replies '"Because the ungrateful AI always seems to decide that humans are inferior and need to be eliminated'"
This isn't the right mindset we should welcome AI, not attack them
This is either a huge mistake or intentional
Gaming X Trio 4080.
I'm going to put in different fans anyway, so whatever is preinstalled isn't going to matter that much.
1 hour ago, Rob_dog said:
Gaming X Trio 4080.
I would get the deepcool cc560 then and top mount the rad Deepcool CC560 ATX Mid Tower Case (R-CC560-BKGAA4-G-1) - PCPartPicker
They are both excellent cases for thermals once all fans are installed. The H5 seems to be slightly better in terms of airflow, but this doesn’t make the 4000D a bad case (for reference I have a 4000D and set all my fans to minimum regardless of workload - AIO included - and I hardly have any issues whatsoever - see disclaimer below).
However, a lot of it also depends on which one you like the most which is subjective.
Disclaimer: I also have a 5800X as a CPU but I limited its maximum power draw losing ~0.1 GHz when turboing. Whereas for my GPU I do not really play graphically heavy games.
CPU: Ryzen 7 5800X Cooler:  Corsair H100i Platinum SE Mobo: Asus B550-A Gaming GPU: EVGA RTX 2070 XC RAM: G.Skill Trident Z RGB 3200MHz 16CL 4x8GB SSD0: Crucial MX300 525GB SSD1: Samsung QVO 1TB PSU: NZXT C650 Case: Corsair 4000D Airflow Monitor: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 1600 (3.6GHz; 1.25v) Cooler:  EVGA CLC 240mm Mobo: Asus Strix B350-i GPU: GT 1030 4GB RAM: G.Skill Trident Z 3200MHz 14CL 2x8GB SSD: ADATA SU800 128GB HDD: Seagate Ironwolf 2x6TB PSUCorsair SF450 Case: NZXT H200i
The H5 Flow bottom fan is cool and it gives some air directly to the GPU. The 4000D is also a nice case. Which one would you prefer?
