Future proof for how long?
Solved by johnno23,
nope......... 40 series are totally over priced and any benefit you get is minimal unless you start going 4k.
your system can handle almost anything you throw at it with 1080p and pretty much all games at high settings on a 1440p.
just dont fall into the ultra setting trap.........Ultra is almost impossible to see in a game when running compared to high settings.
And even then you can just drop the shadows to medium and gain a few FPS.
