Build Advice
Go to solution Solved by Why_Me,
@downinthemorgue none of the posters on this thread mentioned the fact that your choice of RAM is slow as molasses not to mention I can think of faster gaming cpu's such as this one down below.
PCPartPicker Part List
CPU: *AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($449.00 @ Amazon)
CPU Cooler: *Deepcool LT720 85.85 CFM Liquid CPU Cooler  ($139.99 @ Amazon)
Motherboard: *MSI MAG B650 TOMAHAWK WIFI ATX AM5 Motherboard  ($219.99 @ Amazon)
Memory: *G.Skill Trident Z5 Neo RGB 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($134.99 @ Amazon)
Storage: *Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($99.99 @ Newegg)
Video Card: PowerColor Red Devil Radeon RX 7900 XTX 24 GB Video Card  ($1019.99 @ Newegg)
Case: *Lian Li LANCOOL 216 ATX Mid Tower Case  ($99.99 @ Newegg)
Power Supply: Corsair RM1000x (2021) 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  ($188.98 @ Amazon)
Total: $2352.92
Generated by PCPartPicker 2023-05-23 17:16 EDT-0400
Generated by PCPartPicker 2023-05-23 17:05 EDT-0400
A better look at those components.
https://lian-li.com/product/lancool-216/
https://www.msi.com/Motherboard/MAG-B650-TOMAHAWK-WIFI
https://www.techpowerup.com/review/amd-ryzen-7-7800x3d/
https://www.tomshardware.com/reviews/deepcool-lt720-aio-cooler
https://www.westerndigital.com/products/internal-drives/wd-black-sn770-nvme-ssd#WDS200T3X0E
Budget (including currency): 2750 USD
Country: USA
Games, programs or workloads that it will be used for: Call of Duty Multiplayer, Call of Duty Zombies, ARK Survival 1 and 2, Resident Evil Remakes, DOOM 2016 and Eternal, Minecraft, Terraria, GTA 5, Dark Souls and Elden Ring, Battlefield 2042 and a lot of older games.
Other details My Build so Far: https://pcpartpicker.com/list/G9PtjZ. I don't need peripherals and I currently am upgrading from a old gaming laptop. I plan to buy my pc part by part hopefully by July., My hope is that this build can handle 1080p 240hz at high-ish settings or 1440p 144hz at (hopefully) high-ish settings. I don't care about 4k or ray tracing just high frames and resolution. I plant to use 2 monitors one 1080p 144hz and the other 1440p 240hz. The main display will be the 1440p monitor for gaming and the other one I've always used for multitasking. Please let me know if my linked build is enough for what I want im new to pc building. Thank You!!!
Your list looks good if willing to spend the money for another $100 US you can get a rtx 4080 it has a 13% performance difference(better). over your rx 7900 xtx
Thanks ill take that into consideration!
unmm no the 7900xtx is a better card then the 4080 stick with that
That's a relief I like the price of the rx 7900 xtx in comparison to the 4080.  Thanks for the advice!
Total: $2352.92
CPU Cooler: *Deepcool LS720 SE 85.85 CFM Liquid CPU Cooler  ($109.99 @ Newegg)
Total: $2322.92
https://www.techpowerup.com/review/deepcool-ls720-aio-360-liquid-cpu-cooler/
Thanks for this! I didn't realize I chose slow RAM. This new price is even better thank you!!
