fps problems with my ryzen 5 5600G
Solved by filpo,
3 minutes ago, Smaili oussama said:The issue is i get low fps 50fps 30fps average in games like valorant and csgo
( i set my vram to 4gb) nothing changed
i see alot of people with the same apu and get 100+ fps average
check the power usage in game (it may be mobo vrm limited)
Also check the cpu usage and ram/gpu usage
I would also get another stick of ram as @deadlou666 said (optimally 16 to make 32)
