BF4 - ramdisk (sry if its wrong section)
Go to solution Solved by Priller,
I was going to say you need an SSD or 32GB of ram but with all of the patching BF4 is now at 39GBs. So you would need an X79 board with alot of ram inorder to put BF4 completely on a ramdisk. Not to mention it would take a while during bootup and shutdown as it would have to load all of that info on an SSD or HDD since ram memory is volatile. Once power is shutoff all information goes with it.
I only got an HDD so BF4 is loading realy long. I have 16 gb ram, can i somehow put the BF4 map on a ramdisk so i always load this map very fast as long as i dont shutdown the pc? I just want the map because for the complete game 16gb isnt enough at all :)
If there is a way to do this, please explain me how
https://linustechtips.com/topic/150796-bf4-ramdisk-sry-if-its-wrong-section/
I don't think you can move a single map to a different storage place, all the files should be saved to the same location.
12600k | MSI MEG S280 | SSUPD Meshilicious | Asus ROG STRIX Z690-I | Crucial 16GB 4800MHz CL38 | MSI Gaming 980Ti | CM V850 SFX | WD SN850 1TB, WD SN550 1TB
Pi 4TB NAS | Asus VG27AQ, Asus PB278Q | Logitech G Pro X Superlight | Glorious G-HXL-STEALTH | Keychron K4 V2 | Sennheiser HD 599 w/ Fiio E10
I don't think that you can do this with a single map. I think it would have to be the entire game.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
the point is´that if have the game on ram and you got like 64GB, it would be worth if you have the pc running very long. PS: my laptop has 4 sodimm slots, and currently i got 2x8GB Kingston 800mhz inside
you need to quote people to make sure they know you have replied :)
Current Build: Case: Define R4 White/Window CPU: i5 3470 @4.0Ghz GPU: GTX 680 DCUII +500Mhz(Mem) Cooler: Hyper 212 EVO Monitor: Acer Monitor 1920x1080 MOBO: Asrock Z77 Extreme 4 Storage: 2TB HDD, 120GB 840 EVO (OS)
Future Build: 4670K, GTX 780 MSI TwinFrozr OC, Z87X-D3H, 8GB @1866Mhz, 120GB SSD, 1TB HDD, 750D, RM 650W, Custom Loop. White/Blue/Black Colour Scheme. I literally cannot wait *_*
  • 3 years later...
I know, it's 2018 now but I just wanted to say, it's totally possible to save parts of the game (*actually any game) on another drive. Like pspfreak said, you can create links between folders and even drives, allowing to redirect requests for a specific file to be loaded from somewhere else.
I myself have my origin games folder on a big hdd with a symbolic link to my ssd raid directing to bf4.
For this to work with a ramdisk you would have to back the ramdisk with an image file that gets loaded to the ramdisk as soon as windows starts.
You don't have to instal the whole game on one drive.
This, heaps of symbolic link programs now exist doing all the work for ya with their easy to follow GUI's.
Copy Files,..Select a Source/Target for the SymLink and be good to go.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
