Microphone not picking up
Solved by Psittac,
13 hours ago, Wayhoo said:My earphones have 3 rings on it. Should I get an adapter that splits my earphones into both the mic and earphone port?
if you're earphones only have 3 contact points then there is no mic. IE: if it looks like this then there is no mic
But if it looks like this then you need a splitter
which would look like this
Not sure where you are but here is one for the states
