I use my vacuum cleaner except plug the tube from the intake with outtake so it pushes air out. No need to waste money on disposable air canisters
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
https://linustechtips.com/topic/1507797-cleaning-pc/#findComment-15946160
A compressor that can keep 2bar going or one of those pc dusters on amazon + a not too firm paint brush is really all you need for most dust.
If its super bad staining/sticking dust drench it in 70% or higher isopropyl alcohol or waterless brake cleaner. (both destroy thermal pads so be warned)
https://linustechtips.com/topic/1507797-cleaning-pc/#findComment-15946225
I don't recommend buying an electric duster like a Datavac if you're just blowing your PC out once in a blue moon. That's an expensive tool that's only really good for one thing. A leaf blower will do the same job and then some.
If you have a Shop Vac, put the hose on the discharge (blowy) side and use that. (If you don't have a Shop Vac, a small one should be less expensive than an electric blower.)
https://linustechtips.com/topic/1507797-cleaning-pc/#findComment-15946256
On 5/18/2023 at 11:15 PM, QuantumForce69 said:
I've never properly cleaned my PC before and its starting to build up, does anyone recommend any good  electric/reusable air compressors? (and yes I know not to let the fans spin while cleaning them)
Thanks guys!
I mean just look at an LMG video on this topic that should give you enough info
https://linustechtips.com/topic/1507797-cleaning-pc/#findComment-15951650
Just a cheapo can of 5* Air Duster and a Soft Bristle paintbrush have always done the trick for me.
Glowing screen captures,
Sleep eludes, lost in pixels,
Restless eyes still yearn.
-ChatGPT; the greatest poet of our generation.
https://linustechtips.com/topic/1507797-cleaning-pc/#findComment-15951922
Take it outside when you blow it out!
Phone 1 (Daily Driver): Samsung Galaxy Z Fold2 5G
Phone 2 (Work): Samsung Galaxy S21 Ultra 5G 256gb
Laptop 1 (Production): 16" MBP2019, i7, 5500M, 32GB DDR4, 2TB SSD
Laptop 2 (Gaming): Toshiba Qosmio X875, i7 3630QM, GTX 670M, 16GB DDR3
https://linustechtips.com/topic/1507797-cleaning-pc/#findComment-15952747
