Cpu not fully turboing
Go to solution Solved by Electronics Wizardy,
The 3.3 boost is a single core boost and is pretty rare to see. You will probalby see that speed on one core if you max out one core and don't have any other programs running.
This seems normal.
So, for a long time now I've had a prett old laptop that still runs great (from 2012) with a core i5 3320m, which is supposed to turbo up to 3.3GHz but only ever goes up to 3.1GHz and even with cpu stress tests it only goes up to 3.1GHz (the exact number is 3093.3GHz). Does anyone have any idea if it's possible to squeeze anything more out of my cpu or is it just because of how old it is?
system specs (full spec list see file):
Computer:      Hewlett-Packard HP EliteBook 8470p
CPU:           Intel Core i5-3320M (Ivy Bridge-MB PGA SV, L1)
               2600 MHz (26.00x100.0) @ 3093 MHz (31.00x99.8)
Motherboard:   Hewlett-Packard 179B
BIOS:          68ICF Ver. F.40, 01/31/2013
Chipset:       Intel QM77 (Panther Point)
Memory:        8192 MBytes @ 798 MHz, 11-11-11-28
               - 4096 MB PC12800 DDR3 SDRAM - Samsung M471B5173QH0-YK0
               - 4096 MB PC12800 DDR3 SDRAM - Samsung M471B5173CB0-YK0
Graphics:      Intel Ivy Bridge-MB GT2 - Integrated Graphics [E1/L1/N0/P0] [Hewlett-Packard]
               Intel HD Graphics 4000, 2112 MB
Drive:         Samsung SSD 870 EVO 1TB, 976.8 GB, Serial ATA 6Gb/s @ 6Gb/s
Drive:         hp CDDVDW SN-208DB, DVD+R DL
Drive:         MSFT XVDD, Disk drive
Sound:         Intel Panther Point PCH - High Definition Audio Controller [C1]
Network:       Intel 82579LM (Lewisville) Gigabit Ethernet Controller
Network:       Intel Centrino Ultimate-N 6300 AGN 3x3 HMC WiFi Adapter
OS:            Microsoft Windows 10 Professional (x64) Build 19045.2846
DESKTOP-R7E5O51.LOG
https://linustechtips.com/topic/1505605-cpu-not-fully-turboing/
This seems normal.
Do you think it could be possible to get both cores to go to 3.3GHz instead of only a single core?
https://linustechtips.com/topic/1505605-cpu-not-fully-turboing/#findComment-15929507
