Budget (including currency): 20000sek or about 2000€/$ idm going a bit over but hard limit would be 3000
Country: Sweden
Games, programs or workloads that it will be used for: Strategy games but also graphic games like hell let loose and other games that require graphics as I want the option to have it on high or even ultra.
The only desired part is a graphic card in the 4000 series otherwise it’s free play tips and suggestions would be very helpful.
https://linustechtips.com/topic/1505321-need-help-building-a-gaming-pc/
What monitor resolution do you plan on playing at? Also, are you asking for an entire PC build or just the GPU? Because 4000 Series will very quickly eat up your budget if you're not careful lol.
Keep in mind that I am sometimes wrong, so please correct me if you believe this is the case!
"The Nvidia Geforce RTX 3050 is brutally underrated"
Rn i have 1920x1080 but might upgrade to 2k later and I’m asking for a entire Pc build and idm going a little over budget hard limit would be 3000
DDR4
PCPartPicker Part List
CPU: *Intel Core i5-13400F 2.5 GHz 10-Core Processor  (kr2536.00 @ Amazon Sweden)
CPU Cooler: *Deepcool AK400 66.47 CFM CPU Cooler  (kr436.00 @ CDON SE)
Motherboard: *Gigabyte B760 GAMING X DDR4 ATX LGA1700 Motherboard  (kr1713.90 @ Amazon Sweden)
Memory: *Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  (kr749.00 @ Amazon Sweden)
Storage: *Crucial P3 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (kr1299.51 @ Amazon Sweden)
Video Card: *Asus DUAL GeForce RTX 4070 12 GB Video Card  (kr7690.00 @ Proshop)
Case: *Fractal Design Focus 2 ATX Mid Tower Case  (kr854.55 @ Amazon Sweden)
Power Supply: *Corsair RM750x (2021) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (kr1149.00 @ Amazon Sweden)
Operating System: *Microsoft Windows 11 Home OEM - DVD 64-bit  (kr1366.00 @ Amazon Sweden)
Case Fan: *ARCTIC P12 56.3 CFM 120 mm Fan  (kr67.00 @ Amazon Sweden)
Total: kr17860.96
Generated by PCPartPicker 2023-05-06 22:02 CEST+0200
A better look at those components.
https://www.fractal-design.com/products/cases/focus/focus-2/black-tg-clear-tint/
https://www.gigabyte.com/Motherboard/B760-GAMING-X-DDR4-rev-10#kf
https://ark.intel.com/content/www/us/en/ark/products/230501/intel-core-i513400f-processor-20m-cache-up-to-4-60-ghz.html
https://www.deepcool.com/products/Cooling/cpuaircoolers/AK400-Performance-CPU-Cooler-1700-AM5/2021/15222.shtml
DDR5
Motherboard: *Gigabyte B760 GAMING X AX ATX LGA1700 Motherboard  (kr2157.64 @ Amazon Sweden)
Memory: *G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory  (kr1372.00 @ CDON SE)
Case Fan: *ARCTIC P12 56.3 CFM 120 mm Fan  (kr79.00 @ CDON SE)
Total: kr18939.70
Generated by PCPartPicker 2023-05-06 22:09 CEST+0200
AM5
CPU: *AMD Ryzen 5 7600X 4.7 GHz 6-Core Processor  (kr2853.70 @ Amazon Sweden)
Motherboard: *Asus PRIME B650-PLUS ATX AM5 Motherboard  (kr2156.66 @ Amazon Sweden)
Memory: *G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL32 Memory  (kr1434.00 @ Computersalg)
Total: kr6444.36
Generated by PCPartPicker 2023-05-06 22:33 CEST+0200
