Simple SG-05 AIO ITX Build
Scheer
So this will be another rebuild of a computer for my son to play minecraft on.
The build went pretty well, I've done a few other ITX builds and this case was no more difficult even being quite a bit smaller than most to fit an AIO and decent sized GPU. The only issue I have right now is that the power supply fan is not working. It will spin a few turns upon powering off, so I'm afraid the fan is working and the controller is what is broken. Unfortunately I did not test this before hand and have already chopped a few wires off... so I doubt they are going to warranty it for me. I'll give them a call and see, but will likely end up buying a new 80mm x 15mm fan to try out, as I've hear this PSU is quite loud.
SPECS:
Gigabyte H61-USB3
Intel i3-2100t
Sapphire 7790
2x2GB Mushkin Silverline
Silverstone 300w SFX
Coolermaster 120V
Silverstone SG-05
I couldn't pass up the Coolermaster 120V for $50 from Amazon, and was actually very surprised with the build quality of it and ease of installation.
I'm sure that it really doesn't matter, but the backplate is MUCH more robust than what Corsair provides with their AIO kits.
The two downsides to Coolermaster's system I found was the force applied to the CPU is based on the back of the motherboard, where-as Corsairs is from the front. This means you will be applying different amounts of force depending on the thickness of the motherboards PCB rather than the set distance using Corsair's method. The other downside is that Coolermaster for some reason decided to go with slotted nuts...
To fit the radiator in the case, you need to either leave the ODD/HDD tray out, or do a bit of modification to it. As I wanted to use it for cable management I decided to drill out the rivets holding the two pieces together, trashed the HDD part of the mount, and bent a tab back strait for clearance.
When installing the radiator I found my biggest gripe with this case, the fan filter. In order to remove it you must take off the case cover, then pry up 6 tabs that hold the front panel on, then flex it out of its mount. I'm sure they could have come up with a way to remove it without all the hassle.
The AIO just barely fits  :D
Front panel connectors sleeved.
Power supply installed and cables ran. The USB3 cable was tucked out of the way until I get an adapter for it. Despite the -USB3 suffix of the motherboards model... this motherboard does not have a 3.0 header on it. I have a 2.0 to 3.0 adapter somewhere, but haven't been able to find it yet.
And after a quick bit of cable management, here it is completed.
And finally, here it is playing some Minecraft.
that isn't a 7990, right?
also this looks like the 450 watt version
Whoops, typo. 7790.
It is the 300w version, but yes it does look similar to the 450w. This only has one 6 pin EPS connector on it tho.
Nice job on the cables ! Looks like a really sweet small system.
i5 4440 || Prolimatech Lynx w/ Noiseblocker BlacksilentPRO PL-PS || GA-Z87MX-D3H || 16GB HyperX Red & Savage || Asus GTX 970 Turbo OC @ 1403/7600 || 840 & WD 1TB Blue || Samson SR850 & Samson SR950 & ATH-M50 Red & Cloud II + Fiio e7 + Xonar U7 || Razer Tournament Edition 2014 & Kana v2 || Seasonic G 450 >> Nanoxia DS4
Got a new PSU for it, one that actually works.  :D
I ended up chopping off several connectors as I don't plan on the PSU leaving this build, leaving it with only one each sata and molex plugs. The 4+4 CPU power was split and half of it sleeved, along with the sata cable. Removing all the unnecessary connectors really helped with cable management.
I may sleeve the 6 pin connector at some point, but the 24 pin will be left alone as there isn't enough room to neatly fish 24 cables side by side down to the motherboard.
You might want to flip around the fan on the radiator, the way it is currently positioned it will suck all the hot air from the radiator back into the case. You are better off venting the hot air out and having no intake than pulling in more heat and having no exhaust. I've actually done some tests on airflow and fan positioning, and I've found that one fan venting hot air cools more efficiently than that same fan pulling in cool air instead.
Quote
Ignis (Primary rig)
CPU
 i7-4770K                               Displays Dell U2312HM + 2x Asus VH236H
MB ASRock Z87M Extreme4      Keyboard Rosewill K85 RGB BR
RAM G.Skill Ripjaws X 16GB      Mouse Razer DeathAdder
GPU XFX RX 5700XT                    Headset V-Moda Crossfade LP2
PSU Lepa G1600
Case Corsair 350D
Cooling Corsair H90
Storage PNY CS900 120GB (OS) + WD Blue 1TB
Quote
Server 01Alpha                                       Server 01Beta                            Chaos Box (Loaner Rig)                Router (pfSense)
CPU
 Xeon X5650                                      CPU 2x Xeon E5520                    CPU Xeon E3-1240V2                     CPU Xeon E3-1246V3
MB Asus P6T WS Pro                               MB EVGA SR-2                             MB ASRock H61MV-ITX                 MB ASRock H81 Pro BTC
RAM Kingston unbuffered ECC 24GB  RAM G.Skill Ripjaws 16GB         RAM Random Ebay RAM 12GB    RAM G.Skill Ripjaws 8GB
GPU XFX R5 220                                       GPU EVGA GTX 580 SC               GPU Gigabyte R9 295x2                GPU integrated
PSU Corsair CX430M                               PSU Corsair AX1200                   PSU Corsair GS700                         PSU Antec EA-380D
Case Norco RPC-450B 4U                      Case Rosewill  RSV-L4000C        Case Modified Bitfenix Prodigy   Case Norco RPC-250 2U
Cooling Noctua NH-U9S                        Cooling 2x CM Hyper 212 Evo  Cooling EVGA CLC 120mm           Cooling stock
Storage PNY CS900 120GB (OS)           Storage null                                 Storage PNY CS900 120GB (OS)  Storage Fujitsu 150GB HDD
               8x WD Red 1TB in Raid 6        WD Black 1TB
               WD Green 2TB
I though about it, but I'd rather have the positive pressure in the case than to pull all the dust in from the back of the desk that will likely not be cleaned. This weekend I will be doing a quick stress test and will watch the system temps to see if it needs to be changed.
its a "t" processor, so it really doesn't produce any heat, typically it is about 10 degrees F above ambient. I only bought the AIO to eliminate a fan.
Dude, ive wanted to do this build for years, its the best itx case imo, stupidly small yet runs cool with an AIO - Awesome :)
OnePlus 6T
May also want to look at the FT-03 Mini, it is larger but has a smaller footprint on your desk and looks 10x better, the fan filter is also easy to remove. I only went with this as I already have an FT-03 Mini and wanted to mix it up a bit. Also, I didn't want to spend $100 on a case for a four year old.  :P
