Psu Help
Solved by johnt,
3 hours ago, fate333 said:Yea I knew which ones were the molex cables. But I have a bunch of em left because idk what to do with them. Like I said all the fans are plugged into the mobo, so do I just not need them? The RGB controllers were all connected using SATA cables already. So I'm gonna assume I don't need them then?
Correct. You won’t need the molex cables if you don’t have anything that needs it.
Featured Topics
saltycaramel ·
Posted in Tech News0 -
2
VinSen ·
Posted in New Builds and Planning2 -
1
Fahizzle ·
7
INotPablo ·
Posted in CPUs, Motherboards, and Memory1
