AIO Cooling needs multiple restarts
Go to solution Solved by that_potato_guy,
11 minutes ago, Sadleast said:
On the Gigabyte Page are Versions since F4. My version i updated from is F2. I would try going one step back from F6B to F6?
Yes go one step back and see if it solves and watch gamernexus's video on new amd cpus burning and stuff idk if it affects 7700x or not but still it's good to take precautions
Hey Fellas,
Since i did a BIOS update for my Ryzen 7 7700X i need multiple restarts for my AIO MSI Coreliquid 240R V2 to cool my CPU. When im starting my PC Temps just begin to rise with fans spinning on 100% but with no affect. After some restarts it just works and the CPU wont exceed 50 Degrees and fans spinning normal. I already checked if everything is plugged in properly and i checked BIOS if somethings not showing up. Im out of Ideas.
Motherboard: Gigabyte B650 Gaming X AX with Bios Version F6B
https://linustechtips.com/topic/1505109-aio-cooling-needs-multiple-restarts/
3 minutes ago, that_potato_guy said:
Maybe it's that voltage thing going on with am5 rn. I think you should roll back to the previous bios
Yeah i will try. Thank you very much.
Rolling back is the most idiotic thing you could do. The older bios are the ones that are using too high of voltage.... You want to be on the latest one possible.
CPU-AMD Ryzen 7 7800X3D GPU- Gigabyte WindForce SFF RTX 5070ti MOBO-ASUS ROG Strix B650E-E Gaming Wifi RAM-32gb G.Skill Trident Z5 Neo DDR5 6000cl30 STORAGE- 2TB Samsung 990 Pro PCIE4 NVME x2 PSU-Corsair RM1000x Shift COOLING-Lian Li GA II Lite 360mm with 3x Lian Li P28 + 4 Lian Li TL120 (Intake) CASE-Phanteks NV5 MONITORS-Samsung G61 QD-OLED 1440p 240hz +Gigabyte G24F 1080p 180hz PERIPHERALSVaxee XE-S+Padsmith Crucible Mousepad+Monsgeek M1 V5 TMR+Autonomous ErgoChair+ AUDIO-Audient iD4 Mk II + Rode NTH100
The one i can do is from 30.03.2023 and already after the update for Ryzen 7000. but what you suggest?
That should be the case generally but it's the new one that caused him the problem so there's only one thing to do and that's why I also told him to watch gamernexus's video.
What do you think is the problem if it's not the bios cuz he only mentioned he updated bios that caused it
Also. Gigabyte Pulled back F6 and F6b from their site. So probably they are faulty
9 minutes ago, that_potato_guy said:
Well now you know why it's not available amd really messed this up
Yep this is why i will take the latest which is available on their site which is the F5 BIOS and i hope this will fix it. And i will wait for them to release new ones.
