Help me choose.
Go to solution Solved by flibberdipper,
AMD wins all the way.
is this a htcp build or what
My Rig
PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksY
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($379.00 @ shopRBC)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($34.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($78.83 @ DirectCanada)
Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory  ($139.99 @ Memory Express)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($71.34 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($92.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card  ($298.98 @ Newegg Canada)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.99 @ NCIX)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($116.00 @ shopRBC)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm  Fans  ($23.99 @ NCIX)
Monitor: HP 22xi 60Hz 21.5" Monitor  ($187.11 @ Amazon Canada)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($114.99 @ NCIX)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($76.99 @ Amazon Canada)
Headphones: Kingston HyperX Cloud Pro Headset  ($78.98 @ DirectCanada)
Total: $2074.22
Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100
Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0
Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/
https://linustechtips.com/topic/150490-help-me-choose/#findComment-2010699
http://pcpartpicker.com/user/evilmeister13/saved/4DCF
VS
http://pcpartpicker.com/user/evilmeister13/saved/4DIy
Im pretty sure the AMD is the obvious choice, just wanna know what you guys think. Im ordering these tonight
If youre looking to install Windows 7/8.1 on an SSD a 64GB isnt going to cut it. I suggest you bump it up to a 120GB.
As for choosing the setup, if your not going to overclock, id choose the intel setup.
If you are planning to overclock, id choose the AMD setup
https://linustechtips.com/topic/150490-help-me-choose/#findComment-2010706
Windows 7 will fit on there just fine, i looked it up.
https://linustechtips.com/topic/150490-help-me-choose/#findComment-2010731
Looking it up and experiencing it is different. I had a 64GB SSD and it took up 60GB of the space. Take it from the experienced, it wont fit.
Obviously it did if your using it. And all i need it to do is fit, nothing more. Its just gonna be a boot drive
https://linustechtips.com/topic/150490-help-me-choose/#findComment-2010757
Leaving the psu that way to future proof a little bit.
Also, just for clarification, win 7 pro 64 bit does install on 4gb of ram right?
technology wont consume more power in the future.
430 is way to much! 500 would fit 780 and 4770.
and yes, it does.
and 64gb will fit, but not much data at all on it since ssds get slower when you fill them up.
emulation.
https://linustechtips.com/topic/150490-help-me-choose/#findComment-2010786
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/150490-help-me-choose/#findComment-2010843
Love this guy every time he pops up in one of my posts
Aww, thanks. :wub:
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/150490-help-me-choose/#findComment-2011716
