So i finally decided to build a PC, i already have the ram, a 350 watt power supply, the hard drive, OS, monitor, mouse, keyboard, an optical drive and even an xbox 360 controller, so i wouldn't mind help for the parts i need with my low budget.
I was thinking of something like this http://pcpartpicker.com/p/3Idaj
Should i instead get something like a Radeon R7 265 or a GTX 750 TI for lower wattage? Perhaps there are parts with better value?
My monitor also has a resolution of 1440x900 and only a vga port. I really wanted to get a better one but i was thinking on using this one till i get the money.
Any help is greatly appreciated  :D
Edited by RagingMan
https://linustechtips.com/topic/150464-350-pc-build-help/
What's the system being used for?
https://linustechtips.com/topic/150464-350-pc-build-help/#findComment-2012199
that seems like a good build for the money personally though I would go with a case that allows for a 120mm fan in the rear and a bottom mounted power supply but for the cost that seems like a good case
current build and total cost   http://linustechtips.com/main/topic/150083-thrift-shop-build/
I apologize for my crappy English I'm American
https://linustechtips.com/topic/150464-350-pc-build-help/#findComment-2012248
https://linustechtips.com/topic/150464-350-pc-build-help/#findComment-2012384
Wait, isn't that Power Supply just regular ATX? Will it really work with the other parts?
Yeah--What's wrong with atx?
Yes, it'll work just fine.
https://linustechtips.com/topic/150464-350-pc-build-help/#findComment-2012414
I remember i had a problem with a Power Supply because it was regular ATX and wasn't compatible with the motherboard, but i guess i can trust you, and PCPartPicker doesn't mention incompatibility.
I actually found that exact same Power Supply laying around the house, i never resold it, that definetly helps, i updated the list again to go with my needs. http://pcpartpicker.com/p/3HMdV .
But i was thinking maybe the 350 watt power supply won't be enough, should i keep the r7 265/gtx 750 ti and upgrade something else?
https://linustechtips.com/topic/150464-350-pc-build-help/#findComment-2012421
If you really want the best bang for your buck, get the R7 265.  Also someone mentioned getting a better motherboard, and that would be good too, since your whole computer really is built all around it.  That build does look very good, it should run just about any game on at least high settings!
https://linustechtips.com/topic/150464-350-pc-build-help/#findComment-2018030
What you have picked out will do fine.
Gaming/Editing PC: AMD FX-8350 | CM Seidon 120V Liquid Cooler | Asus M5A99FX PRO R2.0 ATX AM3+ Motherboard | G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600| Gigabyte GeForce GTX 770 2GB WINDFORCE | PNY XLR8 240GB SSD | Seagate Barracuda 2TB HDD | Corsair 600W ATX Semi-Modular PSU | Thermaltake Chaser A71 | LG 25UM64-S 25.0" 2560 x 1080 Display | CM Storm Devastator Gaming Keyboard & Mouse
https://linustechtips.com/topic/150464-350-pc-build-help/#findComment-2018109
