Been building PCs for a long time now and haven't had many issues. Built this one, had a few issues but got it to post. Installed Windows 10, no ethernet, tried installing drivers but kept getting an windows not supported error. Restarted many times, had no real issues. Contacted ASUS live chat, he told me to clear CMOS. Did that with the power off, posts fine but then when I try to exit bios I get a black screen. Everytime I boot in it's just a black screen.
It's a ROG Strix Z690-E, I got an M.2, 32GB of Ram and a RTX Ventus 3060, I'm thinking it's MOBO related.
https://linustechtips.com/topic/1504276-help-with-my-new-build/
try reseating your cpu, gpu, ram and using bios flashback to update your bios as @Popo576 said.
Can you still boot into windows fine?
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1504276-help-with-my-new-build/#findComment-15919292
I reseated everything, same issue.
Decided to RMA the MOBO, going to try another board - it's in mail, any idea if it could be just the MOBO being borked?
https://linustechtips.com/topic/1504276-help-with-my-new-build/#findComment-15919320
I had same issue with Ethernet drivers. It was compatible but would not update them. Never had the issue on Asus motherboard, but I now had it in a gigabyte motherboard.  Bios updated too. This was on a fresh installation of Windows 10. Downloaded Ethernet drivers from another computer and still no go. I think I had to do a manual install using the zip archive. Then I ran windows update for rest of patches.
I am on Windows 11 now and did not incur the same issue with Ethernet.
https://linustechtips.com/topic/1504276-help-with-my-new-build/#findComment-15919534
