New build for my 11 year old cousin, please help
I'd get these:
CPU: ($170)
Intel Core i5-12400F | (pcandparts.com)
Motherboard: ($170)
ASRock B760M Pro RS/D4 WiFi DDR4 LGA1700 | (pcandparts.com)
Memory: (Get two of these) ($76)
HyperX Fury Beast 16GB (1 x 16GB) DDR4-3200 RAM | (pcandparts.com)
Storage: ($50)
Kingston SNV2S/1000G M.2 1TB PCIe 4.0 NVMe SSD | (pcandparts.com)
Power Supply: ($100)
Cooler Master G700 700W Gold Efficiency PSU | (pcandparts.com)
Pick whichever GPU you want between those two. The 3060ti is only a little slower, but if you can afford the 3070 go for it. How much would this reseller want for a 6700xt or 6800xt? Both of those GPUs are usually a much better value, with the 6700xt usually being cheaper than the 3070 for similar performance, and the 6800xt being way faster than the 3070 for usually only costing a little bit more.
