Hello friends
i am facing a issue i have a system with ryzen 5 5600 with sapphire rx 6700 10gb graphics card case is Corsair carbide 100r with one intake 120 mm fan and one exhaust 120 mm fan both fans are nzxt 2000rpm fan .
when i play games like Forza horizon 5 in extreme settings the GPU cur temperature goes from 77- 80 and GPU junction temperature goes from 88-107 in other games like rdr2 gpu junction temp is below 100 all the time.
I want to know if I forget about the GPU junction temperature and keep on playing games is it dangerous for the system components or graphics card kindly help as I don't have budget to spend now .
https://linustechtips.com/topic/1504020-temperature-issue-rx6700/
Have you tried undervolting your GPU? That can help reduce some temperature down. I would be concerned with junction temp reaching 107c, but not in dangerous territory yet. Happened to me before when I pushed junction temp too high, maybe beyond 112C PC would safely shut down.
PC spec: CPU: RYZEN 9 9950X3D | GPU: SAPPHIRE NITRO+ 7900XTX | MB: MSI MAG TOMAHAWK x870 RAM: G.SKILL TRIDENT Z NEO 64GB (2x32GB) DDR5-6000 30-40-40-96 COOLING: ARCTIC LIQUID FREEZER III 360, BE QUIET! SILENT WINGS 120 & 140mm| CASE: ANTEC C8 | UPS: POWERSHIELD COMMANDER TOWER 1100VA
PERIPHERALS: KEYBOARD: CORSAIR K95 PLATINUM XT BROWN SWITCH | MOUSE: LOGITECH G502X PLUS WIRELESS | CONTROLLER: PDP AFTERGLOW WIRED CONTROLLER, DUALSENSE
DISPLAYS: GIGABYTE MO34WQC2 2x DELL S2721DGF | LG C1 48"
HT & audio stuff:  AVR: MARANTZ SR7013 | STEREO AMPLIFIER: YAMAHA AS-501 | SPEAKERS: DALI OBERON 7 & DALI ZENSOR 1 & 2x SVS-SB2000 | HEADPHONE DAC+AMP: TOPPING L30+E30 | HEADPHONE: SENNHEISER HD6XX, BOSE QUIETCOMFORT 35 II | MICROPHONE: AUDIO-TECHNICA AT9934USB | BLU-RAY PLAYER: PANASONIC UB820
Well, you've put an already warm GPU in an oven basically, so it's to be expected. It's not still scary though. RX 6000 series usually ramp to 80+ degrees unless you have a case with extremely good airflow (i also don't have one). Critical T Junction on the 6700 is 110°C and it should shut off if it reaches it, but it will pull down the clocks before that happens.
| Ryzen 7 5800X3D | Arctic Liquid Freezer II 360 Rev 7| AsRock X570 Steel Legend |
| 4x16GB G.Skill Trident Z Neo 4000MHz CL16 | Sapphire Nitro+ RX 6900 XT | Seasonic Focus GX-1000|
| 512GB A-Data XPG Spectrix S40G RGB | 2TB A-Data SX8200 Pro| Phanteks Eclipse G500A |
