So i bought 3200mhz 2x8 ram and put it in my pc (had 8 gb before).
i put the new ram speed in and i think it said it was at 2133 speed.
so i went into the bios and set it to xmp 1 (3200mhz)
i clicked save and exit but my system wouldn`t post
the leds of my motherboard would turn on but no gpu/cpu or normal fans were spinnig.
took out the cmos battery and put it back in after 10 mins, but no result anyone know how to solve this?
(i tried putting my old ram but no post)
did you do this with the PSU plugged in?
I hit 700W on an i5 with a NHD15
Also I'm 14 so please just confirm anything I say with someone more experienced
2 minutes ago, rafaelsnake said:
nope
psu cable out and pressed power butten couple of times
run in single channel mode (take one stick out)
30 minutes ago, rafaelsnake said:
does it matter which one?
mobo is asrock b250 gaming k4
btw i found out my i5-7400 supports up to 2400mhz (i think)
Your motherboard does not support 3200 mhz just run it 2133 to be safe.
The motherboard site also says up to 2400 mhz
15 minutes ago, rafaelsnake said:
the problem is that it doesn`t post even after removing battery and putting old ram in
Have you attempted to reinstall your previous RAM since? AKA normalizing it back to the previous hardware configuration?
Builder/Enthusiast/Overclocker since 2012 with a focus on SFF/ITX since 2014.
How long was the battery out?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
