Need help in deciding ram frequency
Solved by brob,
12 hours ago, ig_harsha_gamer7 said:Budget (including currency): 1600$
Country: India
Games, programs or workloads that it will be used for: Popular AAA titles
I want to pair my i5-13600k with 3600mhz 8*2 gb ram, but i noticed that the processor supports only upto 3200mhz, is there any way to use the 3600mhz ram fully?
Intel officially supports automatic memory overclocking through the use of XMP. If the memory kit supports XMP, one simply needs to enable the feature in the BIOS and if necessary select the desired profile.
