[build logs] Project GCSE (English school qualifications)
Chris1204
I am currently 16 and from England, i built my first PC for my 15th birthday and here it is pictured. During this and last year i designed and built a dedicated table for it, for my D.T gcse project pictured below thankyou!
The specs are not much but here it is:
GPU: Amd 7770
Cpu: Amd fx 6300 @4.6ghz
Cooler: corsair h60 (2013) with 2 enermax tb silence fans
MB: msi 970a-g43
HDD: 2* 500GB 7200rpm
SSD: 3* mix and match 60GB
Optical Drive: standard
Fan controller: nzxt sentry 2
Fans: 3* enermax tb silence w/ 1 12cm stock blue fan at front and 2 random fans at right side
Future: I plan to get a 770 and an nzxt g10 with 1*120mm rad and a 360mm rad for cpu (ill cut a section from the case)
It has been marked and for it i got 28/32
should've built just a table for it, not with the case inside, it'd be cool ahah
i should've done something like that for my project :(
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
i started with that idea but i had time limitations
Does anyone know of a 770 or 280x or better that has a pcb shorter than 26cm?
