I hate Lian Li.
Solved by Avocheeseado,
Your parts list looks perfect
AMD recommend a 750W PSU for the 7900XTX so something like this would be plenty (unless you plan to do a lot of overclocking - if so there isn't really a way around paying $300 for an 1000w sfx)
you might also want more storage than that if you are planning on playing lots of games - go with a 2tb nvme
