FX 8320 Overheating Issue?
Solved by Priller,
Put in the original fans. The QE fans will only spin up to about 1200rpm.
Check for dust on the face of the radiator.
Use ET6. It will report accurate temps.
MadManMarsBar ·
Posted in Build Logs0 -
IAmAndre ·
Posted in New Builds and Planning3 -
4
2
Playgb2 ·
Posted in Troubleshooting1 -
1
1
5
1
play_circle_filled
Latest From ShortCircuit:
