psu 12pin
Solved by Poinkachu,
10 minutes ago, hollyh88 said:so im not really well informed when it comes to psu's being able to work with the new nvidia 12pins. Mine of course only has regular 6+2 pins. But i do see those adapters and of course you can put 2 8 pins or 6+2 pins on them but as far as i know that doesnt make your psu automatically compatible right? So my question is.. is my psu compatible with such gpu pins?
my psu is a 850fx or Seasonic Focus Plus 850 Gold.
Basically they're simply 12v & GND wires, just in different layout / pinout.
Seasonic sells their version of 8pin to 12vhpwr custom PSU cable, which looks better & easier to route and stuffs. https://seasonic.com/12vhpwr-cable
Or you can buy one from cablemod, either it's adapter or custom PSU cable.
