Budget (including currency): 500-1000
Country: USA
Games, programs or workloads that it will be used for: mostly Gaming, probably other things on the side.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I have a parts list figured out already but I’d like an experts opinion on critiquing it since I’m kind of new to the pc building area. I already have the keyboard, mouse, and monitors. I just need something that will play most games well. Just something that isn’t slow.
Parts list I’ve made
Ryzen 5 5600X
Asus ROG Strix b550-f
16gb Corsair vengeance ram
Samsung 970 Evo plus 500 gb m.2
WD caviar blue 1 TB hard drive
MSI ventus RTX 3060 12gb
Fractal design pop air case
Corsair RM750e
This comes out to 985 usd
I have none of the parts in hand and I’d preferably like to buy new but used parts are also an option.
Partpicker link
https://pcpartpicker.com/user/Jman2/saved/#view=T3FK7P
https://linustechtips.com/topic/1501015-looking-for-help-with-a-pc-build/
5 minutes ago, Tomberry said:
lots of info for us to work with here. pls give us a budget and what you want to use if for at the minimum
I know I accidentally posted on accident and couldn’t figure out how to delete a post so I just was editing it. My bad my bad
I'd post a https://pcpartpicker.com/ build, as then its easy to modify and to see if you are overpaying for some components, but the specs alone arent too bad. Personally i'd get a 5600 instead of a 5600X and get a 2TB HDD. Also whats the ram speed?
I have a PCpartpicker list if you’d like me to post it. Ram speed is 3200.
9 minutes ago, Tomberry said:
how much is a 6700xt? could be a good option
I forgot to include this in the main post but I’d preferably like Nvidia but I suppose Radeon is also an option.
6700xt at the cheapest new is 350 according to partpicker
PCPartPicker Part List
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  ($140.90 @ Amazon)
Motherboard: MSI PRO B550M-VC WIFI Micro ATX AM4 Motherboard  ($119.99 @ Amazon)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory  ($51.99 @ Newegg)
Storage: TEAMGROUP MP33 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($44.99 @ Amazon)
Video Card: ASRock Phantom Gaming D OC Radeon RX 6800 XT 16 GB Video Card  ($539.99 @ Newegg)
Case: Thermaltake Versa H18 MicroATX Mini Tower Case  ($42.99 @ Newegg)
Power Supply: Corsair RM750e 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.99 @ Corsair)
Total: $1040.84
Generated by PCPartPicker 2023-04-15 14:29 EDT-0400
Total: $1040.84
this is a great build much better than the origional but it might be worth waiting a few weeks for amd to release there 7800xt (idk when it is going to be but it must be soon)
