CPU Fan Error?
Go to solution Solved by MegaDave91,
I do have a fan plugged
Optional CPU fan header or the main CPU fan header?
If you don't have a fan plugged into the CPU fan header, you'll get that error.
Your motherboard thinks there's no fan for your CPU.
https://linustechtips.com/topic/150062-cpu-fan-error/#findComment-2005697
https://linustechtips.com/topic/150062-cpu-fan-error/#findComment-2005703
yes
Yes to which?
https://linustechtips.com/topic/150062-cpu-fan-error/#findComment-2005714
Which one is your pump plugged into?
https://linustechtips.com/topic/150062-cpu-fan-error/#findComment-2005724
CPU_FAN
Is the pump PWM?
https://linustechtips.com/topic/150062-cpu-fan-error/#findComment-2005740
